Possible Oscilator Problem?
Quote:I'll start start chipping away at it.
Do not "chip away", there is risk of mechanical damage that could obscure how it was made. Do look for poor connections to the errant coil winding, usually at the terminations. Besides, if it is an easy fix, the heat will drive off 90 years of moisture. A solvent such as mineral spirits will dissolve bees wax too.
Warm with a heat gun, bees wax only needs 140F or so... Look for poor connections at terminals, green spots are corrosion. Keep heat away if mineral spirits are used, fire danger. Spirit fumes will be carburized by heat gun, toxic, as well as dangerous
If intent is rewind, number of turns, wire size (type) is important. If there is a insulating layer between coils, that is celluloid and decays then corrodes the wire...
Chas
Pliny the younger
Possible Oscilator Problem? - by Kahuna59 - 10-10-2023, 09:48 AM
RE: Possible Oscilator Problem? - by Chas - 10-10-2023, 06:07 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-11-2023, 11:51 AM
RE: Possible Oscilator Problem? - by Chas - 10-11-2023, 02:17 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-12-2023, 12:05 PM
RE: Possible Oscilator Problem? - by Chas - 10-12-2023, 12:48 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-12-2023, 03:36 PM
RE: Possible Oscilator Problem? - by Kahuna59 - 10-23-2023, 07:26 AM
Eico 232 VTVM Schematic
There are currently 6157 online users. [Complete List]
» 1 Member(s) | 6156 Guest(s)
