Philco Model 37-38B Questions
Richard & Morzh -
Great Information! Thanks Guys!
Yes that lug on the Volume pot IS connected internally to A+. I saw the glob of solder on the lug and "assumed" that it used to have a connection to it.
I also looked again at the Cap on the CT of the Volume pot. It must have been replaced at sometime way in the past. It has a Solar Brand cap and all the others are Philco Brand. Probably just picked one that seemed to work, in the past. I will replace it with the original value.
And finally, yes the added length of the outer windings would certainly add to the resistance! I thought it might be something much more technical. Keep It Simple!
Thanks
John N3MUN
Philco Model 37-38B Questions - by jjfritz5528 - 10-14-2023, 12:32 PM
RE: Philco Model 37-38B Questions - by morzh - 10-14-2023, 01:33 PM
RE: Philco Model 37-38B Questions - by radiorich - 10-14-2023, 01:49 PM
RE: Philco Model 37-38B Questions - by jjfritz5528 - 10-14-2023, 02:44 PM
RE: Philco Model 37-38B Questions - by morzh - 10-14-2023, 03:51 PM
RE: Philco Model 37-38B Questions - by morzh - 10-19-2023, 08:31 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8603 online users. [Complete List]
» 2 Member(s) | 8601 Guest(s)
