37-630 Possible Silver Migration Problem
T'aint. I have a few grinding wheels of different grit, and a professonal grade dental lab drill (like a dremil but ball bearings, too bad I can no longer see well enough to make this an advantage.) Grind but do not crack, if crack, crazy glue and wait. and solder quick and sure. Sure don't be wanting to show the green unless it is a certain day in the spring. Prayer also helps. Whomever disigned this, I hope they did not have children.
Re: 37-630 Possible Silver Migration Problem - by codefox1 - 07-01-2011, 07:50 PM
The speaker table error?
Philco 70 antenna lead
There are currently 6157 online users. [Complete List]
» 1 Member(s) | 6156 Guest(s)
