Philco 48-482-"brick wall"
While waiting for some "caps" to come in....I thought I'd try using my P-Touch label maker. for the push buttons...started with white with black print....didn't like that.  So I tried black with white print and I think I'll stick with that...
Unable to find the clear caps that slid over the brown pushbuttons...
Thanks for looking,
Mike
Philco 48-482-"brick wall" - by EagleRiverMike - 10-06-2023, 12:11 PM
RE: Philco 48-482-"brick wall" - by Jayce - 10-06-2023, 03:47 PM
RE: Philco 48-482-"brick wall" - by Jayce - 10-06-2023, 05:46 PM
RE: Philco 48-482-"brick wall" - by radiorich - 10-06-2023, 08:02 PM
RE: Philco 48-482-"brick wall" - by Jayce - 10-06-2023, 08:56 PM
RE: Philco 48-482-"brick wall" - by klondike98 - 10-06-2023, 09:09 PM
RE: Philco 48-482-"brick wall" - by EagleRiverMike - 10-21-2023, 06:17 PM
