Motorola hybrid set 24ME Comet car radio
Hi,
You always find something interest to service! As Joe mentioned the service info is here on pg 51: https://www.worldradiohistory.com/Archiv...n-1962.pdf  I haven't had direct experience with that model, but I have with the 12ME which is the 1960/61 version.
I have a parts chassis (12ME) because I needed a volume/tone/off-on switch. I would hazard a guess and say that the pcb is solder to the metal framework of the chassis. Which makes it a bit of a nuisance to remove. I'll take a look and see if I can find that chassis.
RE: Motorola hybrid set 24ME Comet car radio - by Radioroslyn - 10-24-2023, 08:45 AM
Eico 232 VTVM Schematic
There are currently 3206 online users. [Complete List]
» 2 Member(s) | 3204 Guest(s)
