Philco 625B Assessment (UPDATE It works!)
Today I removed one of the coils to replace the old wire. All of the coils check out OK and it's ready to be re-installed.
Unfortunately the more I look at the chassis wiring, the more damage that I see. Much of the cloth wiring is badly deteriorated and broken, thereby exposing potential shorts. I also found signs of insect or rodent damage. It looks like I will end up replacing much of the wiring. I think I will use modern wire under the chassis and new cloth wire on top.
I purchased the speaker from Ebay today. (Thanks for the heads up Terry!) I am waiting on my order of capacitors and resistors from  JustRadios.com
Since I am taking the chassis down this far, I may as well repaint it also. Anyone know if the tube shields are mild steel? They look to be plated in some kind of brass. I am not exactly sure where to go with that. Any tips would be much appreciated...
Bud - KI5OMM
RE: Philco 125 Assessment - by morzh - 10-22-2023, 07:56 PM
RE: Philco 125 Assessment - by KI5OMM - 10-22-2023, 08:08 PM
RE: Philco 125 Assessment - by Ron Ramirez - 10-22-2023, 08:59 PM
RE: Philco 625B Assessment - by morzh - 10-22-2023, 10:39 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-22-2023, 10:41 PM
RE: Philco 625B Assessment - by morzh - 10-22-2023, 10:44 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-22-2023, 11:03 PM
RE: Philco 625B Assessment - by KI5OMM - 10-23-2023, 08:08 AM
RE: Philco 625B Assessment - by KI5OMM - 10-23-2023, 08:50 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-23-2023, 09:45 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-23-2023, 12:10 PM
RE: Philco 625B Assessment - by morzh - 10-23-2023, 04:59 PM
RE: Philco 625B Assessment - by KI5OMM - 10-23-2023, 08:04 PM
RE: Philco 625B Assessment - by RodB - 10-23-2023, 08:36 PM
RE: Philco 625B Assessment - by morzh - 10-23-2023, 09:20 PM
RE: Philco 625B Assessment - by KI5OMM - 10-24-2023, 11:28 AM
RE: Philco 625B Assessment - by Ron Ramirez - 10-24-2023, 11:51 AM
RE: Philco 625B Assessment - by KI5OMM - 10-24-2023, 03:02 PM
RE: Philco 625B Assessment - by morzh - 10-24-2023, 04:18 PM
RE: Philco 625B Assessment - by KI5OMM - 10-24-2023, 05:10 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-24-2023, 05:24 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-24-2023, 05:56 PM
RE: Philco 625B Assessment - by radiorich - 10-24-2023, 11:14 PM
RE: Philco 625B Assessment - by KI5OMM - 10-25-2023, 02:19 PM
RE: Philco 625B Assessment - by KI5OMM - 10-26-2023, 09:15 AM
RE: Philco 625B Assessment - by RodB - 10-26-2023, 10:05 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-26-2023, 10:49 AM
RE: Philco 625B Assessment - by morzh - 10-26-2023, 11:38 AM
RE: Philco 625B Assessment - by KI5OMM - 10-27-2023, 09:43 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-27-2023, 10:55 AM
RE: Philco 625B Assessment - by KI5OMM - 10-27-2023, 05:12 PM
RE: Philco 625B Assessment - by Chas - 10-27-2023, 10:24 PM
RE: Philco 625B Assessment - by radiorich - 10-28-2023, 12:04 AM
RE: Philco 625B Assessment - by KI5OMM - 10-28-2023, 07:54 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-28-2023, 08:36 PM
RE: Philco 625B Assessment - by KI5OMM - 10-29-2023, 03:23 PM
RE: Philco 625B Assessment - by Ron Ramirez - 10-29-2023, 03:29 PM
RE: Philco 625B Assessment - by KI5OMM - 10-29-2023, 05:12 PM
RE: Philco 625B Assessment - by Ron Ramirez - 10-29-2023, 08:03 PM
RE: Philco 625B Assessment - by David - 10-30-2023, 12:23 PM
RE: Philco 625B Assessment - by KI5OMM - 10-30-2023, 08:48 PM
RE: Philco 625B Assessment - by radiorich - 10-31-2023, 10:03 AM
RE: Philco 625B Assessment - by KI5OMM - 10-31-2023, 11:51 AM
RE: Philco 625B Assessment - by David - 10-31-2023, 02:08 PM
RE: Philco 625B Assessment - by KI5OMM - 10-31-2023, 03:21 PM
RE: Philco 625B Assessment - by Chas - 10-31-2023, 05:19 PM
RE: Philco 625B Assessment - by radiorich - 11-01-2023, 12:38 AM
RE: Philco 625B Assessment - by radiorich - 11-01-2023, 12:41 AM
RE: Philco 625B Assessment - by KI5OMM - 11-01-2023, 07:28 AM
RE: Philco 625B Assessment - by KI5OMM - 11-01-2023, 09:58 AM
RE: Philco 625B Assessment - by morzh - 11-01-2023, 01:19 PM
RE: Philco 625B Assessment - by KI5OMM - 11-01-2023, 01:44 PM
RE: Philco 625B Assessment - by KI5OMM - 11-07-2023, 08:51 PM
