Philco 625B Assessment (UPDATE It works!)
#53
You get extra points for being observant! Actually the nuts were still loose when that photo was taken. The nut that is closest to the shell is the grounding lug. Everything is now properly placed.
Also on another note: I wired the two caps wrong and had to change them up a bit after noticing my mistake on the schematic.
RE: Philco 125 Assessment - by morzh - 10-22-2023, 07:56 PM
RE: Philco 125 Assessment - by KI5OMM - 10-22-2023, 08:08 PM
RE: Philco 125 Assessment - by Ron Ramirez - 10-22-2023, 08:59 PM
RE: Philco 625B Assessment - by morzh - 10-22-2023, 10:39 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-22-2023, 10:41 PM
RE: Philco 625B Assessment - by morzh - 10-22-2023, 10:44 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-22-2023, 11:03 PM
RE: Philco 625B Assessment - by KI5OMM - 10-23-2023, 08:08 AM
RE: Philco 625B Assessment - by KI5OMM - 10-23-2023, 08:50 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-23-2023, 09:45 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-23-2023, 12:10 PM
RE: Philco 625B Assessment - by morzh - 10-23-2023, 04:59 PM
RE: Philco 625B Assessment - by KI5OMM - 10-23-2023, 08:04 PM
RE: Philco 625B Assessment - by RodB - 10-23-2023, 08:36 PM
RE: Philco 625B Assessment - by morzh - 10-23-2023, 09:20 PM
RE: Philco 625B Assessment - by KI5OMM - 10-24-2023, 11:28 AM
RE: Philco 625B Assessment - by Ron Ramirez - 10-24-2023, 11:51 AM
RE: Philco 625B Assessment - by KI5OMM - 10-24-2023, 03:02 PM
RE: Philco 625B Assessment - by morzh - 10-24-2023, 04:18 PM
RE: Philco 625B Assessment - by KI5OMM - 10-24-2023, 05:10 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-24-2023, 05:24 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-24-2023, 05:56 PM
RE: Philco 625B Assessment - by radiorich - 10-24-2023, 11:14 PM
RE: Philco 625B Assessment - by KI5OMM - 10-25-2023, 02:19 PM
RE: Philco 625B Assessment - by KI5OMM - 10-26-2023, 09:15 AM
RE: Philco 625B Assessment - by RodB - 10-26-2023, 10:05 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-26-2023, 10:49 AM
RE: Philco 625B Assessment - by morzh - 10-26-2023, 11:38 AM
RE: Philco 625B Assessment - by KI5OMM - 10-27-2023, 09:43 AM
RE: Philco 625B Assessment - by Radioroslyn - 10-27-2023, 10:55 AM
RE: Philco 625B Assessment - by KI5OMM - 10-27-2023, 05:12 PM
RE: Philco 625B Assessment - by Chas - 10-27-2023, 10:24 PM
RE: Philco 625B Assessment - by radiorich - 10-28-2023, 12:04 AM
RE: Philco 625B Assessment - by KI5OMM - 10-28-2023, 07:54 PM
RE: Philco 625B Assessment - by Radioroslyn - 10-28-2023, 08:36 PM
RE: Philco 625B Assessment - by KI5OMM - 10-29-2023, 03:23 PM
RE: Philco 625B Assessment - by Ron Ramirez - 10-29-2023, 03:29 PM
RE: Philco 625B Assessment - by KI5OMM - 10-29-2023, 05:12 PM
RE: Philco 625B Assessment - by Ron Ramirez - 10-29-2023, 08:03 PM
RE: Philco 625B Assessment - by David - 10-30-2023, 12:23 PM
RE: Philco 625B Assessment - by KI5OMM - 10-30-2023, 08:48 PM
RE: Philco 625B Assessment - by radiorich - 10-31-2023, 10:03 AM
RE: Philco 625B Assessment - by KI5OMM - 10-31-2023, 11:51 AM
RE: Philco 625B Assessment - by David - 10-31-2023, 02:08 PM
RE: Philco 625B Assessment - by KI5OMM - 10-31-2023, 03:21 PM
RE: Philco 625B Assessment - by Chas - 10-31-2023, 05:19 PM
RE: Philco 625B Assessment - by radiorich - 11-01-2023, 12:38 AM
RE: Philco 625B Assessment - by radiorich - 11-01-2023, 12:41 AM
RE: Philco 625B Assessment - by KI5OMM - 11-01-2023, 07:28 AM
RE: Philco 625B Assessment - by KI5OMM - 11-01-2023, 09:58 AM
RE: Philco 625B Assessment - by morzh - 11-01-2023, 01:19 PM
RE: Philco 625B Assessment - by KI5OMM - 11-01-2023, 01:44 PM
RE: Philco 625B Assessment - by KI5OMM - 11-07-2023, 08:51 PM
