Philco 48-482 Alignment
After digging a bit I found this off of the Antique Radio site by Tom Albrecht....
https://antiqueradios.com/forums/viewtop...6&t=284598
So I'll attempt his method.....
Mike
Philco 48-482 Alignment - by EagleRiverMike - 11-03-2023, 01:33 PM
RE: Philco 48-482 Alignment - by EagleRiverMike - 11-04-2023, 10:48 AM
RE: Philco 48-482 Alignment - by EagleRiverMike - 11-04-2023, 03:45 PM
RE: Philco 48-482 Alignment - by RodB - 11-05-2023, 10:04 AM
RE: Philco 48-482 Alignment - by EagleRiverMike - 11-05-2023, 07:12 PM
RE: Philco 48-482 Alignment - by klondike98 - 11-06-2023, 02:54 PM
