1953 Emerson 724
Started on this Emerson 724 the other day. Only 4 paper caps to stuff and one dual electrolytic. The underside looks pretty much like the original after the recap. Radio is playing now with a bit of static; it seems very sensitive to the fluorescent and LED lighting in the shop. I'll do an alignment and then take a look at the Telechron clock to see if that's all working. There is a very faded note on the back of the set that seems to indicate the alarm and sleep mode might not be working. Taking the clock apart will be a new adventure for me if it needs work. The cabinet needs some cleanup, perhaps refreshing the Emerson lettering a bit as well. A cute little set. More later.....[Image: https://www.dropbox.com/scl/fi/nogc8cuf0...avky&raw=1]
[Image: https://www.dropbox.com/scl/fi/2wfu3dw6l...0fu7&raw=1]
Before recap
[Image: https://www.dropbox.com/scl/fi/46macqx25...iisg&raw=1]
After recap
[Image: https://www.dropbox.com/scl/fi/zx8c8eosz...w84v&raw=1]
1953 Emerson 724 - by klondike98 - 12-08-2023, 02:43 PM
RE: 1953 Emerson 724 - by David - 12-08-2023, 07:05 PM
RE: 1953 Emerson 724 - by klondike98 - 12-08-2023, 07:59 PM
RE: 1953 Emerson 724 - by radiorich - 12-08-2023, 09:01 PM
RE: 1953 Emerson 724 - by klondike98 - 12-09-2023, 06:15 PM
RE: 1953 Emerson 724 - by David - 12-09-2023, 10:16 PM
RE: 1953 Emerson 724 - by klondike98 - 12-13-2023, 09:47 PM
RE: 1953 Emerson 724 - by David - 12-14-2023, 01:50 PM
RE: 1953 Emerson 724 - by klondike98 - 12-16-2023, 12:02 AM
RE: 1953 Emerson 724 - by Paul Philco322 - 12-16-2023, 01:27 PM
RE: 1953 Emerson 724 - by klondike98 - 12-16-2023, 01:54 PM
RE: 1953 Emerson 724 - by GarySP - 12-16-2023, 03:17 PM
RE: 1953 Emerson 724 - by Eliot Ness - 12-19-2023, 09:24 PM
