Philco 87 Alignment
https://philcoradio.com/library/index.ph...receivers/
Probably the best description of minimum signal is at it's lowest point. The 87 has no avc so you can dump a whole lot of signal into it if you need to.
Got an 87 myself, it's a heavy brute!
Philco 87 Alignment - by gellenb - 12-11-2023, 08:00 PM
RE: Philco 87 Alignment - by Radioroslyn - 12-11-2023, 09:07 PM
RE: Philco 87 Alignment - by morzh - 12-11-2023, 10:15 PM
RE: Philco 87 Alignment - by gellenb - 12-12-2023, 06:50 PM
RE: Philco 87 Alignment - by morzh - 12-12-2023, 11:00 PM
RE: Philco 87 Alignment - by Chas - 12-13-2023, 11:28 AM
RE: Philco 87 Alignment - by MrFixr55 - 12-13-2023, 11:14 PM
RE: Philco 87 Alignment - by morzh - 12-13-2023, 11:20 PM
RE: Philco 87 Alignment - by MrFixr55 - 12-14-2023, 09:03 AM
RE: Philco 87 Alignment - by RodB - 12-14-2023, 11:01 AM
RE: Philco 87 Alignment - by fwmartin2000 - 12-17-2023, 07:41 PM
