Philco 37-61
I have a bit of a dilemma that concern the rectifier tube in my 37-61 ,  the model calls for a 5Y4 rectifier, but my radio came with a 5Y3 , the socket is also set up for a 5Y3, I am wondering if some of the 37-61s ever came from the factory with 5Y4s or did someone rewire it. I know even though the 2 tubes do the same thing but the pin outs are different . The cant be interchanged without changing the wiring. I never would noticed this if my radio hadn't come with the rectifier tube, I would have gone by what the schematic and documents said.
Chip
The process of learning is to fix something that is not broke.
Philco 37-61 - by 7chip7 - 12-11-2023, 09:04 PM
RE: Philco 37-61 - by Radioroslyn - 12-11-2023, 10:44 PM
RE: Philco 37-61 - by 7chip7 - 12-11-2023, 11:23 PM
RE: Philco 37-61 - by GarySP - 12-11-2023, 11:31 PM
RE: Philco 37-61 - by Radioroslyn - 12-12-2023, 01:11 AM
RE: Philco 37-61 - by 7chip7 - 12-12-2023, 11:18 AM
RE: Philco 37-61 - by klondike98 - 12-12-2023, 01:48 PM
RE: Philco 37-61 - by 7chip7 - 12-12-2023, 03:38 PM
RE: Philco 37-61 - by klondike98 - 12-13-2023, 02:01 PM
RE: Philco 37-61 - by MrFixr55 - 12-14-2023, 09:12 AM
RE: Philco 37-61 - by 7chip7 - 12-16-2023, 12:22 PM
RE: Philco 37-61 - by radiorich - 12-16-2023, 01:50 PM
RE: Philco 37-61 - by klondike98 - 12-16-2023, 05:44 PM
RE: Philco 37-61 - by 7chip7 - 12-18-2023, 11:27 AM
RE: Philco 37-61 - by 7chip7 - 12-18-2023, 11:47 AM
RE: Philco 37-61 - by David - 12-18-2023, 01:37 PM
RE: Philco 37-61 - by 7chip7 - 12-24-2023, 09:44 AM
RE: Philco 37-61 - by RodB - 12-24-2023, 10:33 AM
RE: Philco 37-61 - by Radioroslyn - 12-24-2023, 10:38 AM
RE: Philco 37-61 - by 7chip7 - 12-25-2023, 11:17 AM
RE: Philco 37-61 - by Radioroslyn - 12-25-2023, 03:03 PM
RE: Philco 37-61 - by RodB - 12-25-2023, 04:51 PM
RE: Philco 37-61 - by 7chip7 - 12-26-2023, 07:25 AM
RE: Philco 37-61 - by Radioroslyn - 12-26-2023, 10:17 AM
RE: Philco 37-61 - by 7chip7 - 12-26-2023, 11:29 AM
RE: Philco 37-61 - by Radioroslyn - 12-26-2023, 05:09 PM
RE: Philco 37-61 - by RodB - 12-26-2023, 08:48 PM
RE: Philco 37-61 - by 7chip7 - 12-27-2023, 08:08 AM
RE: Philco 37-61 - by 7chip7 - 12-30-2023, 08:22 AM
RE: Philco 37-61 - by Radioroslyn - 12-30-2023, 09:01 AM
RE: Philco 37-61 - by 7chip7 - 12-30-2023, 09:45 AM
RE: Philco 37-61 - by RodB - 12-30-2023, 09:49 AM
RE: Philco 37-61 - by 7chip7 - 12-30-2023, 02:03 PM
RE: Philco 37-61 - by 7chip7 - 12-30-2023, 04:30 PM
RE: Philco 37-61 - by RodB - 12-30-2023, 05:53 PM
RE: Philco 37-61 - by 7chip7 - 12-31-2023, 02:18 PM
RE: Philco 37-61 - by RodB - 01-01-2024, 12:03 PM
RE: Philco 37-61 - by Radioroslyn - 01-01-2024, 01:44 PM
RE: Philco 37-61 - by 7chip7 - 01-01-2024, 03:40 PM
37-61 Speaker Repair - by 7chip7 - 01-03-2024, 09:01 AM
