38-9 bullet - how bad is too bad?
It always a stark contrast between whatever the top of teh chassis is (whether clean, dusty, or plain awful like in your case) and the inside which is most of the time is sparkling clean, sans an occasional dead 90 y.o. spider.
38-9 bullet - how bad is too bad? - by kiwi_steve - 12-31-2023, 09:13 AM
RE: 38-9 bullet - how bad is too bad? - by morzh - 12-31-2023, 02:48 PM
RE: 38-9 bullet - how bad is too bad? - by Arran - 12-31-2023, 05:55 PM
RE: 38-9 bullet - how bad is too bad? - by morzh - 01-01-2024, 01:43 PM
RE: 38-9 bullet - how bad is too bad? - by morzh - 01-02-2024, 07:52 PM
RE: 38-9 bullet - how bad is too bad? - by David - 01-02-2024, 09:44 PM
RE: 38-9 bullet - how bad is too bad? - by Arran - 01-03-2024, 02:46 AM
RE: 38-9 bullet - how bad is too bad? - by David - 01-03-2024, 02:47 PM
RE: 38-9 bullet - how bad is too bad? - by David - 01-05-2024, 07:45 PM
