38-9 bullet - how bad is too bad?
Hello Steve,
Well done on your set so far I need to get back to work on my Philco 38-10T but I have a customers Clock to finish up this weekend !
38-9 bullet - how bad is too bad? - by kiwi_steve - 12-31-2023, 09:13 AM
RE: 38-9 bullet - how bad is too bad? - by morzh - 12-31-2023, 02:48 PM
RE: 38-9 bullet - how bad is too bad? - by Arran - 12-31-2023, 05:55 PM
RE: 38-9 bullet - how bad is too bad? - by morzh - 01-01-2024, 01:43 PM
RE: 38-9 bullet - how bad is too bad? - by morzh - 01-02-2024, 07:52 PM
RE: 38-9 bullet - how bad is too bad? - by David - 01-02-2024, 09:44 PM
RE: 38-9 bullet - how bad is too bad? - by Arran - 01-03-2024, 02:46 AM
RE: 38-9 bullet - how bad is too bad? - by David - 01-03-2024, 02:47 PM
RE: 38-9 bullet - how bad is too bad? - by radiorich - 01-04-2024, 09:55 PM
RE: 38-9 bullet - how bad is too bad? - by David - 01-05-2024, 07:45 PM
