Philco Radio Model 40-120 IF Transformer Part 32-2327
Hi and welcome,
If the coils are intact then I would hot glue the form to the ceramic. Replace the hardware so that the ceramic portion can be secured back into the can. In the real world what you are looking for is a 455kc IF input transformer that's tuned w/trimmer not w/slugs as you may not have access to the bottom slug. Must be for a tube circuit as ss stuff the impedance's are way too low.
An IF output transformer is not a great idea as the 2ndy impedance is too low to be a good match for the grid of the IF amp grid circuit. On the other hand an interstage transformer would be ok.
GL w/your project!
RE: Philco Radio Model 40-120 IF Transformer Part 32-2327 - by Radioroslyn - 01-09-2024, 10:37 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8509 online users. [Complete List]
» 2 Member(s) | 8507 Guest(s)
