Ford F-1540 Questions
Hi Bill, the tear in the speaker cone is easily patched with a strip of printer paper soaked with wood glue. Carefully smooth the paper over the tear, maybe with a cotton swab. Now here's where the purists will disagree. They'll say to use an acid neutral paper and acid neutral glue. I do use the correct glue and paper but only for the preservation of the cone. Some will have you use a coffee filter or even just cover it with the glue. I disagree with these. The cone is meant to be stiff so it moves as one unit. If you use a flexible patch it won't move the way it's supposed to. The flexible part of the speaker is the surround and should be repaired with a flexible material.
Ford F-1540 Questions - by F-1540 - 12-26-2023, 10:55 PM
RE: Ford F-1540 Questions - by RodB - 12-27-2023, 12:25 AM
RE: Ford F-1540 Questions - by Tim Tress - 12-27-2023, 12:44 PM
RE: Ford F-1540 Questions - by Chas - 12-27-2023, 01:55 PM
RE: Ford F-1540 Questions - by morzh - 12-27-2023, 03:19 PM
RE: Ford F-1540 Questions - by Chas - 12-27-2023, 03:35 PM
RE: Ford F-1540 Questions - by morzh - 12-27-2023, 03:50 PM
RE: Ford F-1540 Questions - by F-1540 - 12-27-2023, 06:18 PM
RE: Ford F-1540 Questions - by morzh - 12-27-2023, 07:11 PM
RE: Ford F-1540 Questions - by David - 12-27-2023, 07:27 PM
RE: Ford F-1540 Questions - by David - 12-27-2023, 07:29 PM
RE: Ford F-1540 Questions - by Chas - 12-27-2023, 08:59 PM
RE: Ford F-1540 Questions - by F-1540 - 12-28-2023, 11:10 PM
RE: Ford F-1540 Questions - by Chas - 12-29-2023, 12:30 AM
RE: Ford F-1540 Questions - by David - 12-29-2023, 03:49 PM
RE: Ford F-1540 Questions - by F-1540 - 01-13-2024, 06:04 PM
RE: Ford F-1540 Questions - by RodB - 01-14-2024, 10:57 AM
RE: Ford F-1540 Questions - by F-1540 - 01-23-2024, 02:28 PM
RE: Ford F-1540 Questions - by RodB - 01-23-2024, 05:54 PM
RE: Ford F-1540 Questions - by F-1540 - 01-23-2024, 06:33 PM
RE: Ford F-1540 Questions - by fenbach - 01-24-2024, 12:05 AM
RE: Ford F-1540 Questions - by radiorich - 01-24-2024, 09:38 AM
RE: Ford F-1540 Questions - by Chas - 01-24-2024, 01:28 PM
RE: Ford F-1540 Questions - by F-1540 - 01-27-2024, 10:00 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 6889 online users. [Complete List]
» 1 Member(s) | 6888 Guest(s)
