Repair tip from Radio Retailer April, 1937
Sprague Kwikette Soldering Aid
Still used today but make your own...
https://www.antiqueradios.com/forums//vi...6&t=192722
Quote:I forget if those little coiled up wires are called squigs or quigs, but I think that Bill Turner used to sell a tool to help making them. It was basically a wooden dowel with a hole in one end and little steel pin for wrapping the wire on.
For NOS
https://www.ebay.com/itm/305164887818
Some refurbishers use these extensively as one does not have to clean out a terminal to get the lead of a replacement part installed. Avoids roasting a terminal strip or breaking a tube socket terminal. Adding heat shrink completes the joint.
Pliny the younger
RE: Repair tip from Radio Retailer April, 1937 - by Chas - 01-15-2024, 01:34 AM
There are currently 9893 online users. [Complete List]
» 1 Member(s) | 9892 Guest(s)
