Chassis Hold-Downs for a 37-116
Here is a pic of my 37-116. As you can see it has the posts on each side of the chassis. It is my understanding that these posts were only used during shipping. I believe the chassis of my 37-116 is only held in place by one single screw at the center of the back of the chassis. This screw is good enough to keep the chassis from falling out of the cabinet, but is nowhere near sufficient to hold that heavy chassis in place if the cabinet is tipped back.
[Image: http://i135.photobucket.com/albums/q136/...7-116I.jpg]
Ed
Chassis Hold-Downs for a 37-116 - by qanerd - 06-22-2011, 12:01 AM
Re: Chassis Hold-Downs for a 37-116 - by etech - 07-08-2011, 07:00 PM
Re: Chassis Hold-Downs for a 37-116 - by qanerd - 07-13-2011, 02:22 PM
There are currently 8941 online users. [Complete List]
» 1 Member(s) | 8940 Guest(s)
