Philco 46-1203 Phono hum. too much?
Radio side sounds awsome. Little to ZERO hum. Had the Shure Crystal P90S Phono cartridge rebuilt by westech services and put it in. Phono is there but hums too much with respect to audio.. what are the suspect things to get rid of it or are they all this bad? I did all the filter caps a few years back maybee 6 years ago..
Bubba
Philco 46-1203 Phono hum. too much? - by BUbba - 07-08-2011, 10:01 PM
There are currently 8737 online users. [Complete List]
» 3 Member(s) | 8734 Guest(s)
