g.e. model 50
thanks to carl and richard i got it fired up today,found bad tube connections at the 12sq7's socket,cleaned and tightened them and she fired up!! i know its a cheap little set but its a great victory for newby! now, how about some help on that philco 77? do you guys know how to bypass the trans? tests open ckt on both side,thanks,phil
g.e. model 50 - by philco fan - 06-17-2006, 10:38 PM
[No subject] - by Guest - 06-18-2006, 12:56 PM
g.e. model 50 - by philco fan - 06-18-2006, 05:26 PM
[No subject] - by rghines1 - 06-18-2006, 09:04 PM
[No subject] - by philco fan - 06-20-2006, 12:01 AM
[No subject] - by rghines1 - 06-20-2006, 04:18 PM
[No subject] - by philco fan - 06-21-2006, 11:32 PM
[No subject] - by Terry Judkins - 06-21-2006, 11:50 PM
[No subject] - by philco fan - 06-23-2006, 12:02 AM
[No subject] - by Terry Judkins - 06-23-2006, 08:14 AM
[No subject] - by Ed Locker - 06-23-2006, 06:31 PM
[No subject] - by philco fan - 06-27-2006, 12:21 AM
[No subject] - by Ed Locker - 06-27-2006, 08:40 AM
