replacement dial light idea!
Hello Everyone,
I am finishing up on my Arvin model 664A that was restored years ago by me.
One of the things that I want to do is to find what would be a good substitute for the dial lamp which is night light type bulb .
It is just too bright and produces to much heat . I worry about the Dial cover warping again .
Good news I found this LED bulb from Amazon
I wanted to post this to let you guys know that this bulb works well and does not interfere with the AM radio band .
Figure this LED is using a capacitor dropper instead of electronics circuit .
H
One thing I want to do is to find what would be a good substitute for the night light dial bulb. It is just too bright and produces too much heat. I worry about the dial cover warping again
replacement dial light idea! - by radiorich - 01-31-2024, 01:48 AM
RE: replacement dial light idea! - by RodB - 01-31-2024, 10:39 AM
RE: replacement dial light idea! - by GarySP - 01-31-2024, 02:42 PM
RE: replacement dial light idea! - by RodB - 01-31-2024, 03:27 PM
RE: replacement dial light idea! - by radiorich - 01-31-2024, 10:27 PM
RE: replacement dial light idea! - by radiorich - 02-01-2024, 10:01 AM
RE: replacement dial light idea! - by David - 02-01-2024, 02:04 PM
