Philco 643 color scheme and modification
After many months of searching, I finally found an unmodified chassis Icon_smile It looks to be all original except for the power/volume control.
Now I can really see how extensive the AC modifications really are. Note that I've removed the power transformer on the AC modified chassis on the right.
[Image: http://farm7.static.flickr.com/6139/5919...9776_z.jpg]
[Image: http://farm7.static.flickr.com/6021/5919...180b_z.jpg]
Re: Philco 643 color scheme and modification - by Bob Andersen - 07-09-2011, 05:32 PM
Users browsing this thread: 14 Guest(s)
There are currently 9915 online users. [Complete List]
» 3 Member(s) | 9912 Guest(s)
