Philco model 76 lowboy
Also looks like the model number of the radio is a Philco 96.
The chassis has the number 76 marked on it in ink.
I assume that someone replaced the original chassis,or did the 96 come with a 76 radio chassis?
Philco model 76 lowboy - by murf - 06-26-2011, 02:53 PM
Re: Philco model 76 lowboy - by 7estatdef - 06-26-2011, 04:20 PM
Re: Philco model 76 lowboy - by murf - 06-26-2011, 04:51 PM
Re: Philco model 76 lowboy - by Chicago Jimmy - 06-26-2011, 06:35 PM
Re: Philco model 76 lowboy - by murf - 06-26-2011, 08:10 PM
Re: Philco model 76 lowboy - by murf - 06-27-2011, 08:19 PM
Re: Philco model 76 lowboy - by Chicago Jimmy - 06-27-2011, 08:39 PM
Re: Philco model 76 lowboy - by murf - 06-27-2011, 08:55 PM
Re: Philco model 76 lowboy - by murf - 06-27-2011, 08:57 PM
Re: Philco model 76 lowboy - by murf - 06-29-2011, 10:20 PM
Re: Philco model 76 lowboy - by 7estatdef - 06-30-2011, 06:59 AM
Re: Philco model 76 lowboy - by 7estatdef - 07-02-2011, 07:34 PM
Re: Philco model 76 lowboy - by murf - 07-02-2011, 09:31 PM
Re: Philco model 76 lowboy - by 7estatdef - 07-02-2011, 11:34 PM
Re: Philco model 76 lowboy - by murf - 07-02-2011, 11:48 PM
Re: Philco model 76 lowboy - by 7estatdef - 07-03-2011, 09:00 AM
Re: Philco model 76 lowboy - by murf - 07-06-2011, 07:36 PM
Re: Philco model 76 lowboy - by murf - 07-08-2011, 06:59 PM
Re: Philco model 76 lowboy - by 7estatdef - 07-08-2011, 08:41 PM
Re: Philco model 76 lowboy - by murf - 07-08-2011, 09:17 PM
Re: Philco model 76 lowboy - by 7estatdef - 07-08-2011, 10:25 PM
Re: Philco model 76 lowboy - by murf - 07-09-2011, 01:12 PM
Re: Philco model 76 lowboy - by 7estatdef - 07-09-2011, 06:33 PM
Re: Philco model 76 lowboy - by murf - 07-09-2011, 07:26 PM
Re: Philco model 76 lowboy - by murf - 07-09-2011, 07:29 PM
Re: Philco model 76 lowboy - by Arran - 07-09-2011, 10:47 PM
Philco 91 Tuning Condenser
There are currently 9754 online users. [Complete List]
» 1 Member(s) | 9753 Guest(s)
