36-650 restoration
Hi Bill
The cap is on the tube, the clip is the signal input to the tube. If you remove the clip you cut off the radio signals and replace them with the signal generator signal. Radios using single ended tubes instruct us to tune the radio to a quiet place on the dial.
BTW if you need parts for your 650 I have two chassis I'm parting out.
36-650 restoration - by Bill Bacco - 02-12-2024, 02:12 PM
RE: 36-650 restoration - by klondike98 - 02-14-2024, 06:17 PM
RE: 36-650 Alignment - by RodB - 02-13-2024, 10:59 AM
RE: 36-650 Alignment - by Bill Bacco - 02-13-2024, 01:25 PM
36-650 High Plate Voltages - by Bill Bacco - 02-13-2024, 01:38 PM
RE: 36-650 High Plate Voltages - by morzh - 02-13-2024, 04:19 PM
RE: 36-650 High Plate Voltages - by Bill Bacco - 02-13-2024, 04:48 PM
RE: 36-650 Alignment - by morzh - 02-13-2024, 04:24 PM
