Antenna coil replacement advice
I have a Fada 6A61 that's been butchered by someone attempting to "restore" it, we're talking multiple wires simply laid next to others held by a drop of solder, the rectifier socket sawzall'd out and replaced with a transformer and who knows what else.
Anyway..... The antenna coil looks like one of the coils was hit by lightning or something similar, all burnt up and the cardboard form is broken too. It's a 5 lug coil, Fada part number 35.122. I can't find any specs on it besides that. Two of the wires are broken and I don't know which coil is which on the schematic.
I also don't know if this set is the 6A60, 6A61, or a late Model 30. The schematic for the 6A61 shows a wave trap as part of the transformer, 6a60 does not.
What are my options for replacing this transformer? Any help is appreciated.
I need more Axial electrolytics.......
Antenna coil replacement advice - by notcalibrated - 02-16-2024, 10:16 AM
RE: Antenna coil replacement advice - by morzh - 02-16-2024, 12:07 PM
RE: Antenna coil replacement advice - by Arran - 02-17-2024, 01:08 AM
RE: Antenna coil replacement advice - by morzh - 02-17-2024, 10:13 PM
