Antenna coil replacement advice
Mike;
In my experience it seems to be the farm radios that end up with burned up antenna coils, at least on the primaries, though I have an AC set in the back room where the antenna coil was removed, and replaced with a ferrite bar antenna. I don't know what happened to the original but possibly a lightning strike took out the primary.
With regard to the O.P I think the upper diagram is the correct one, it shows a center tapped secondary, I guess for the old police band, which may account for what looks like a third coil, the second diagram shows a transformer assembly that if all in one would have seven lugs on it.
RE: Antenna coil replacement advice - by morzh - 02-16-2024, 12:07 PM
RE: Antenna coil replacement advice - by Arran - 02-17-2024, 01:08 AM
RE: Antenna coil replacement advice - by morzh - 02-17-2024, 10:13 PM
