Frozen RF and IF transformers
I think you might want to heat things up a little, and see if they move. A couple of hours in the nice summer sunshine should be OK. You can sand down an old chopstick to fit the groove that is left and with a little gentleness you will move it .
Frozen RF and IF transformers - by Richard Moore - 07-10-2011, 07:49 PM
Re: Frozen RF and IF transformers - by 7estatdef - 07-10-2011, 10:52 PM
Re: Frozen RF and IF transformers - by codefox1 - 07-11-2011, 03:07 PM
Re: Frozen RF and IF transformers - by etech - 07-12-2011, 08:56 AM
Re: Frozen RF and IF transformers - by TA Forbes - 07-12-2011, 12:45 PM
Re: Frozen RF and IF transformers - by copiertech - 12-25-2011, 03:14 PM
Re: Frozen RF and IF transformers - by BDM - 12-25-2011, 06:19 PM
91H Code 126 Restore
There are currently 2269 online users. [Complete List]
» 2 Member(s) | 2267 Guest(s)
