Antenna coil replacement advice
The Emerson was, as I remember, an AC/DC set.
RE: Antenna coil replacement advice - by morzh - 02-16-2024, 12:07 PM
RE: Antenna coil replacement advice - by Arran - 02-17-2024, 01:08 AM
RE: Antenna coil replacement advice - by morzh - 02-17-2024, 10:13 PM
