Batteries for the Philco 39-71!
Building these for a client as we speak. Had to make a set of my own, so I could iron out the bugs.
I'm satisfied with the way these turned out. Had a devil of a time with the A battery. Thought I'd never get the sizing correct. Now it fits like a glove.
My 39-71 now runs on two sets of five 9-volt batteries and four C cells.
Bill
[Image: http://users.mw.net/~bmorris/aysandbees.jpg]
[Image: http://users.mw.net/~bmorris/ainsides.jpg]
[Image: http://users.mw.net/~bmorris/binsides.jpg]
[Image: http://users.mw.net/~bmorris/inside3971.jpg]
Batteries for the Philco 39-71! - by batterymaker - 06-24-2006, 12:49 PM
[No subject] - by Ron Ramirez - 09-19-2006, 09:07 AM
[No subject] - by batterymaker - 09-22-2006, 08:09 AM
[No subject] - by planigan - 09-23-2006, 08:10 PM
[No subject] - by batterymaker - 09-24-2006, 08:52 PM
[No subject] - by planigan - 09-25-2006, 12:06 PM
[No subject] - by batterymaker - 09-25-2006, 02:05 PM
[No subject] - by planigan - 09-27-2006, 10:07 AM
Philco 91 Tuning Condenser
There are currently 9814 online users. [Complete List]
» 1 Member(s) | 9813 Guest(s)
