37-650 output xfmr
When the filter capacitors don't filter any more, then B+ can reach 400+ volts. The increase in plate voltage causes higher than normal plate current which also flows through the transformer primary, poof!
The Hammond 125D was my target. It's a universal 10 watt and accommodates the low H13 speaker impedance. I ended up getting an OPT from a Philco speaker at a garage sale. BTW don't get the one on ePay for $40. The seller is foreign and has no control over his US inventory. Read his feedback.
37-650 output xfmr - by doc612 - 03-10-2024, 03:34 PM
RE: 37-650 output xfmr - by Radioroslyn - 03-10-2024, 05:51 PM
RE: 37-650 output xfmr - by doc612 - 03-10-2024, 09:06 PM
RE: 37-650 output xfmr - by RodB - 03-11-2024, 09:55 AM
RE: 37-650 output xfmr - by doc612 - 03-11-2024, 10:10 AM
RE: 37-650 output xfmr - by RodB - 03-11-2024, 10:43 AM
RE: 37-650 output xfmr - by Chas - 03-11-2024, 01:00 PM
RE: 37-650 output xfmr - by doc612 - 03-11-2024, 02:25 PM
