Philco 60 code 121 IF's
Having trouble with tuning, getting only one station and weak. Recapped and new resistors. Can hear this station with signal tracer very well, radio weak.
Read some threads and things point to the osc coil. Here are my readings with all wiring removed.
These are the coils pin numbers
1 to top wire 4.2 ohms primary coil
1 to 4 2.3
1 to 5 3.8
4 to 5 3.8
2 to 3 3.8 secondary coil
The ohm readings are lower on the schematic. Do you think these are okay.
I believe the osc coil numbering is the same as the antenna coil, numbering clockwise from mount.
Jim
Spring Lake MI
Philco 60 code 121 IF's - by Jimradio - 03-14-2024, 07:43 PM
RE: Philco 60 code 121 IF's - by MrFixr55 - 03-15-2024, 10:16 AM
RE: Philco 60 code 121 IF's - by Jimradio - 03-15-2024, 02:19 PM
RE: Philco 60 code 121 IF's - by Jimradio - 03-19-2024, 07:43 AM
RE: Philco 60 code 121 IF's - by RodB - 03-19-2024, 10:19 AM
RE: Philco 60 code 121 IF's - by Jimradio - 03-19-2024, 01:56 PM
RE: Philco 60 code 121 IF's - by Jimradio - 03-19-2024, 03:32 PM
RE: Philco 60 code 121 IF's - by Radioroslyn - 03-19-2024, 05:29 PM
RE: Philco 60 code 121 IF's - by Jimradio - 03-19-2024, 07:27 PM
RE: Philco 60 code 121 IF's - by Radioroslyn - 03-20-2024, 06:27 AM
RE: Philco 60 code 121 IF's - by Jimradio - 03-20-2024, 09:58 AM
RE: Philco 60 code 121 IF's - by radiorich - 03-21-2024, 09:09 AM
RE: Philco 60 code 121 IF's - by Jimradio - 03-21-2024, 11:46 AM
RE: Philco 60 code 121 IF's - by klondike98 - 03-21-2024, 12:04 PM
RE: Philco 60 code 121 IF's - by Radioroslyn - 03-21-2024, 08:51 PM
RE: Philco 60 code 121 IF's - by Jimradio - 03-22-2024, 07:57 AM
RE: Philco 60 code 121 IF's - by radiorich - 03-22-2024, 08:17 AM
RE: Philco 60 code 121 IF's - by Jimradio - 03-22-2024, 11:19 AM
RE: Philco 60 code 121 IF's - by Radioroslyn - 03-22-2024, 12:55 PM
RE: Philco 60 code 121 IF's - by Jimradio - 03-29-2024, 07:48 AM
RE: Philco 60 code 121 IF's - by RodB - 03-29-2024, 10:36 AM
RE: Philco 60 code 121 IF's - by Jimradio - 03-29-2024, 03:09 PM
RE: Philco 60 code 121 IF's - by Jimradio - 03-30-2024, 03:54 PM
RE: Philco 60 code 121 IF's - by Jimradio - 04-04-2024, 09:47 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9304 online users. [Complete List]
» 1 Member(s) | 9303 Guest(s)
