RCA V-100
The V-100 Is a nice little phono-radio, as many of RCA's sets wer. I haven't my service book within reach for that set,peaker is only a 5 inch, you're wasting time trying to resurrect a cheap speaker. I don't recall if the set has a transformerless power supply, or a power transformer. But your best bet is to just get a PM speaker that fits into the set well, and replace the field with a 2000 ohm 5 watt wire wound resistor.
RCA V-100 - by IraP - 07-12-2011, 10:32 AM
Re: RCA V-100 - by exray - 07-12-2011, 08:59 PM
Re: RCA V-100 - by Doug Houston - 07-13-2011, 11:47 PM
