unknown philoco
i recently purchased a philco at a yard sale. i have searched the internet. can't find on even similar to it. can anyone tell me where to find a model #. it has a part # 10718
unknown philoco - by shirl1789 - 07-14-2011, 04:25 PM
Re: unknown philoco - by Ron Ramirez - 07-14-2011, 04:40 PM
Re: unknown philoco - by shirl1789 - 07-14-2011, 04:44 PM
Re: unknown philoco - by Ron Ramirez - 07-14-2011, 09:12 PM
Re: unknown philoco - by shirl1789 - 07-15-2011, 03:50 PM
Re: unknown philoco - by shirl1789 - 07-15-2011, 04:11 PM
There are currently 9499 online users. [Complete List]
» 2 Member(s) | 9497 Guest(s)
