As Promised: Companion for 84B
So now when you get hungry, you can help yourself to some cookies from your neat new "radio" cookie jar while you enjoy listening to your Philco 84B! Icon_wink
I don't think I've ever seen one in that style before.
As Promised: Companion for 84B - by Uffda - 07-14-2011, 04:25 PM
Re: As Promised: Companion for 84B - by Ron Ramirez - 07-14-2011, 09:06 PM
Re: As Promised: Companion for 84B - by Uffda - 07-15-2011, 01:02 PM
Re: As Promised: Companion for 84B - by codefox1 - 07-15-2011, 06:46 PM
There are currently 10553 online users. [Complete List]
» 2 Member(s) | 10551 Guest(s)
