Philco model 511
Gentlemen and Radio Techs,
I have model 511 Philco I need the information on the cap block on and I need to know which way the electrolytic caps are layed out. I mean which way the plus and minus ends of the cap block go. And also there is a 13k resistor located in the power section that is not mentioned in the schematic. I am sending a picture of the bottom set.
As you can see if you look at the far right in the power section you will see a resistor that is black and blue and I found out that the Philco pre RMA code of that part is 13k.
Is this a late addtion or what? And how are the BC resistor taps are layed out as well?
If anyone can give some aid on this problem that would be helpful.
Philco model 511 - by radionut1929 - 07-15-2011, 11:15 PM
Re: Philco model 511 - by Chuck Schwark - 07-16-2011, 08:54 AM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5127 online users. [Complete List]
» 3 Member(s) | 5124 Guest(s)
