Replacing electrolytics
hello Haydenp,
As morzh "Usually yes. If size is not an issue."
If you have them I would go ahead and use them . lately in some my sets that I plan to keep I have been using them too.
Replacing electrolytics - by Haydenp121 - 04-15-2024, 09:56 AM
RE: Replacing electrolytics - by morzh - 04-15-2024, 11:49 AM
RE: Replacing electrolytics - by radiorich - 04-15-2024, 07:24 PM
RE: Replacing electrolytics - by Arran - 04-16-2024, 01:28 AM
RE: Replacing electrolytics - by morzh - 04-16-2024, 09:49 PM
RE: Replacing electrolytics - by radiorich - 04-16-2024, 10:12 PM
