Philco 60 Higher Frequencies
The feedback winding is the section of the oscillator coil that you rewound. Try adding 4 or 5 more turns to the existing. The rotor is the part of the tuning capacitor turns or rotates with plates. The fixed portion at the bottom w/plates is called the stator.
Sometimes the rotor plates can get bent just a little and rub on the stator. This short the tuning cap out of the circuit. Most or the time it's the rotor plates at either end. They have cuts in them alignment/tracking purposes.
Philco 60 Higher Frequencies - by dconant - 04-17-2024, 06:17 PM
RE: Philco 60 Higher Frequencies - by Radioroslyn - 04-17-2024, 10:05 PM
RE: Philco 60 Higher Frequencies - by dconant - 04-18-2024, 08:09 AM
RE: Philco 60 Higher Frequencies - by Radioroslyn - 04-18-2024, 09:42 AM
RE: Philco 60 Higher Frequencies - by dconant - 04-18-2024, 09:53 AM
RE: Philco 60 Higher Frequencies - by Radioroslyn - 04-18-2024, 10:13 AM
RE: Philco 60 Higher Frequencies - by dconant - 04-18-2024, 03:39 PM
RE: Philco 60 Higher Frequencies - by Steve Davis - 04-18-2024, 06:25 PM
RE: Philco 60 Higher Frequencies - by dconant - 04-18-2024, 06:56 PM
RE: Philco 60 Higher Frequencies - by Radioroslyn - 04-18-2024, 10:19 PM
RE: Philco 60 Higher Frequencies - by dconant - 04-19-2024, 05:43 PM
RE: Philco 60 Higher Frequencies - by Radioroslyn - 04-19-2024, 07:11 PM
RE: Philco 60 Higher Frequencies - by SRv2 - 04-19-2024, 08:59 PM
462ron - by 462ron - 04-20-2024, 08:03 AM
RE: Philco 60 Higher Frequencies - by dconant - 04-20-2024, 08:15 AM
RE: Philco 60 Higher Frequencies - by Ed Locker - 04-20-2024, 10:02 AM
RE: Philco 60 Higher Frequencies - by dconant - 04-20-2024, 11:29 AM
