The reason I asked for a photo was to discover if the antenna is part of the cabinet or mounted on the chassis and how it attaches. You can use any nondestructive method, Including the tacks. I see that the antenna lead wires are soldered so the antenna is meant to be a permanent attachment to the cabinet. If you don't want the tacks you can use a few dabs of hot glue or equivalent, just in case the antenna has to be removed.
You are correct about the safety cap; should be an "X" rated. Just be sure it gets installed after the power switch as in the schematic.
48-461 - by philco4me - 05-03-2024, 04:46 PM
RE: 48-461 - by RodB - 05-03-2024, 10:37 PM
RE: 48-461 - by philco4me - 05-03-2024, 11:07 PM
RE: 48-461 - by philco4me - 05-04-2024, 08:29 AM
RE: 48-461 - by RodB - 05-04-2024, 09:52 AM
RE: 48-461 - by philco4me - 05-04-2024, 10:13 AM
RE: 48-461 - by RodB - 05-04-2024, 01:48 PM
RE: 48-461 - by philco4me - 05-04-2024, 02:13 PM
RE: 48-461 - by morzh - 05-04-2024, 04:53 PM
RE: 48-461 - by philco4me - 05-04-2024, 10:58 PM
RE: 48-461 - by klondike98 - 05-05-2024, 03:32 PM
RE: 48-461 - by philco4me - 05-05-2024, 05:41 PM
RE: 48-461 - by philco4me - 05-07-2024, 08:37 PM
RE: 48-461 - by RodB - 05-08-2024, 09:30 AM
RE: 48-461 - by philco4me - 05-08-2024, 09:47 AM
RE: 48-461 - by klondike98 - 05-08-2024, 08:21 PM
RE: 48-461 - by philco4me - 05-08-2024, 08:33 PM
RE: 48-461 - by philco4me - 05-10-2024, 01:06 PM
RE: 48-461 - by David - 05-10-2024, 03:49 PM
RE: 48-461 - by RodB - 05-10-2024, 03:58 PM
RE: 48-461 - by philco4me - 05-10-2024, 04:05 PM
