Hallicrafters SX-62 - low volume
I can easily lower the heat. I’ll put it back to around 375. I’ve been using this Kester “44” 60/40 solder and that’s the recommended temp. I’ve been using a pointed tip but it’s swappable for a larger angled tip which I have.
Previously I was just using this 40 watt WLC100 Weller with no temperature indicator. I think I was routinely using it at the max which I realize now was wrong.
Thanks. This is all a learning process. Although last week I was watching the tv Show FBI - the terrorist was soldering up their device - I recognized my Weller as the soldering iron they were using - truly I am a radio nerd.
Hallicrafters SX-62 - low volume - by bridkarl - 04-19-2024, 10:23 PM
RE: Hallicrafters SX-62 - low volume - by David - 04-20-2024, 05:08 PM
RE: Hallicrafters SX-62 - low volume - by David - 04-21-2024, 08:35 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 11:21 AM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 02:00 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 06:04 PM
RE: Hallicrafters SX-62 - low volume - by bridkarl - 05-11-2024, 07:05 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 07:58 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-17-2024, 11:57 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8835 online users. [Complete List]
» 3 Member(s) | 8832 Guest(s)
