Hallicrafters SX-62 - low volume
Thanks. I have one of those new led lights with a magnifier which I will be using to check this. I tend to use solid wire rather than stranded - just to avoid these issues with loose strands of wire when using stranded wire. It’s also why in part I chose to use new sockets so that these were new connections instead of being done over old ones. I’ll take a look and see if I have any of this 63/37 solder. I have probably a half dozen of different types in my shop. That’s something I didn’t know - thanks
Hallicrafters SX-62 - low volume - by bridkarl - 04-19-2024, 10:23 PM
RE: Hallicrafters SX-62 - low volume - by David - 04-20-2024, 05:08 PM
RE: Hallicrafters SX-62 - low volume - by David - 04-21-2024, 08:35 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 11:21 AM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 02:00 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 06:04 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-11-2024, 07:58 PM
RE: Hallicrafters SX-62 - low volume - by bridkarl - 05-11-2024, 08:29 PM
RE: Hallicrafters SX-62 - low volume - by Chas - 05-17-2024, 11:57 AM
