Dial - Philco 71
Oh that drive... I used 1.7mm Kevlar fishing line. Rated @ 400lbs, braided, and abrasion resistant. Amazon has it @ $19 for 30'. Used it on my 201X works fine.
Dial - Philco 71 - by Pillo69 - 04-23-2023, 12:10 PM
RE: Dial - Philco 71 - by NostalgiaRadioTime - 04-23-2023, 12:51 PM
RE: Dial - Philco 71 - by Pillo69 - 04-23-2023, 01:44 PM
RE: Dial - Philco 71 - by dmblackburn - 05-10-2024, 11:09 AM
RE: Dial - Philco 71 - by Radioroslyn - 05-11-2024, 04:28 PM
RE: Dial - Philco 71 - by Steve Davis - 05-11-2024, 06:37 PM
RE: Dial - Philco 71 - by dmblackburn - 05-12-2024, 03:51 PM
RE: Dial - Philco 71 - by Radioroslyn - 05-12-2024, 11:27 PM
RE: Dial - Philco 71 - by dmblackburn - 05-13-2024, 08:30 AM
RE: Dial - Philco 71 - by Radioroslyn - 05-13-2024, 09:38 AM
