Hi guys, I had the same issue with the bezel on my 41-221. I used a jewelers screwdriver and a small flat blade screwdriver to get under the clip next to the center. Work one side then the other. It will slowly get looser. I removed all six this way. The main thing is to use a short screwdriver with the thinnest blade.
For the round clips I use a spring hook to hook the center teeth at the post and pull up at the center, working one side then the other.
48-230 - by SRv2 - 05-15-2024, 04:18 PM
RE: 48-230 - by radiorich - 05-15-2024, 07:24 PM
RE: 48-230 - by SRv2 - 05-15-2024, 07:37 PM
RE: 48-230 - by RodB - 05-15-2024, 08:43 PM
RE: 48-230 - by SRv2 - 05-15-2024, 10:07 PM
RE: 48-230 - by radiorich - 05-16-2024, 09:46 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 9734 online users. [Complete List]
» 2 Member(s) | 9732 Guest(s)
