75 Tube
All of the 75 tubes in question have nice clean pins. I have replaced the grid cap wire and cleaned the connector but have not done the pins or resoldered. I'll give that a go today or tomorrow.
75 Tube - by dconant - 05-16-2024, 01:11 PM
RE: 75 Tube - by David - 05-16-2024, 01:39 PM
RE: 75 Tube - by Steve Davis - 05-16-2024, 04:01 PM
RE: 75 Tube - by Arran - 05-16-2024, 08:08 PM
RE: 75 Tube - by radiorich - 05-17-2024, 08:35 AM
RE: 75 Tube - by dconant - 05-17-2024, 09:18 AM
RE: 75 Tube - by David - 05-17-2024, 10:18 AM
RE: 75 Tube - by DaleHCook - 05-17-2024, 10:55 AM
RE: 75 Tube - by tym - 05-26-2024, 12:21 PM
RE: 75 Tube - by morzh - 05-26-2024, 05:29 PM
RE: 75 Tube - by dconant - 06-06-2024, 03:11 PM
