RCA Radiodyne 28
Thanks Chas! Great stuff to know earlier rather than later. I sent for an Arbe-III yesterday and will need to float a loan for the tubes! The set was made as a battery unit but someone put a Radio Receptor Co. eliminator in the battery box which I don’t plan to use. The hookups don’t seem to match what the instruction manual shows. I’m not sure if an attempt to employ the old battery eliminator changed anything. This restoration won’t be a weekend job! I appreciate all the help and support. Stay tuned! - Rob
RCA Radiodyne 28 - by Rob Quay - 05-17-2024, 02:26 PM
RE: RCA Radiodyne 28 - by Radioroslyn - 05-17-2024, 10:06 PM
RE: RCA Radiodyne 28 - by Rob Quay - 05-18-2024, 08:11 AM
RE: RCA Radiodyne 28 - by Chas - 05-18-2024, 12:32 PM
RE: RCA Radiodyne 28 - by Rob Quay - 05-18-2024, 02:14 PM
RE: RCA Radiodyne 28 - by Chas - 05-18-2024, 03:09 PM
RE: RCA Radiodyne 28 - by Rob Quay - 05-18-2024, 04:05 PM
RE: RCA Radiodyne 28 - by Rob Quay - 05-20-2024, 05:07 PM
RE: RCA Radiodyne 28 - by Chas - 05-21-2024, 12:07 AM
RE: RCA Radiodyne 28 - by Rob Quay - 05-21-2024, 10:34 AM
RE: RCA Radiodyne 28 - by Rob Quay - 05-21-2024, 10:36 AM
RE: RCA Radiodyne 28 - by Chas - 05-21-2024, 09:09 PM
RE: RCA Radiodyne 28 - by Rob Quay - 05-22-2024, 12:00 AM
RE: RCA Radiodyne 28 - by Chas - 05-22-2024, 10:25 AM
RE: RCA Radiodyne 28 - by Rob Quay - 05-22-2024, 11:49 PM
RE: RCA Radiodyne 28 - by Chas - 05-23-2024, 12:02 PM
RE: RCA Radiodyne 28 - by Rob Quay - 05-23-2024, 02:07 PM
RE: RCA Radiodyne 28 - by Chas - 05-23-2024, 03:46 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-01-2024, 11:32 AM
RE: RCA Radiodyne 28 - by Rob Quay - 06-01-2024, 06:52 PM
RE: RCA Radiodyne 28 - by Chas - 06-01-2024, 08:09 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-02-2024, 09:07 AM
RE: RCA Radiodyne 28 - by Chas - 06-02-2024, 12:04 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-04-2024, 10:00 AM
RE: RCA Radiodyne 28 - by Chas - 06-04-2024, 11:29 AM
RE: RCA Radiodyne 28 - by Rob Quay - 06-06-2024, 10:17 AM
RE: RCA Radiodyne 28 - by Chas - 06-06-2024, 12:29 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-06-2024, 02:04 PM
RE: RCA Radiodyne 28 - by Chas - 06-06-2024, 03:12 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-06-2024, 04:36 PM
RE: RCA Radiodyne 28 - by Chas - 06-06-2024, 08:56 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-06-2024, 11:40 PM
RE: RCA Radiodyne 28 - by Chas - 06-07-2024, 03:28 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-07-2024, 10:46 PM
RE: RCA Radiodyne 28 - by Chas - 06-09-2024, 04:06 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-09-2024, 05:43 PM
RE: RCA Radiodyne 28 - by Chas - 06-09-2024, 06:51 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-14-2024, 11:45 AM
RE: RCA Radiodyne 28 - by Rob Quay - 06-14-2024, 11:46 AM
RE: RCA Radiodyne 28 - by Chas - 06-14-2024, 02:43 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-16-2024, 11:07 AM
RE: RCA Radiodyne 28 - by Chas - 06-16-2024, 11:42 AM
RE: RCA Radiodyne 28 - by Rob Quay - 06-18-2024, 06:22 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-18-2024, 06:28 PM
RE: RCA Radiodyne 28 - by Chas - 06-18-2024, 06:44 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-18-2024, 10:39 PM
RE: RCA Radiodyne 28 - by Chas - 06-19-2024, 12:39 AM
RE: RCA Radiodyne 28 - by Rob Quay - 06-19-2024, 12:23 PM
RE: RCA Radiodyne 28 - by Chas - 06-19-2024, 02:11 PM
RE: RCA Radiodyne 28 - by Rob Quay - 06-20-2024, 03:18 PM
RE: RCA Radiodyne 28 - by GarySP - 06-20-2024, 04:22 PM
