FM 1000
Thank you gents for your suggestions.
I'm regularly perusing ebay, found a couple that were already sold. Called Find-a-Tube in Feb but they were out. I think I'm going to cycle through my resources again and hopefully find a rogue FM 1000. In the mean time I'll set up a 6BN6 and see if it works.
Thanks again, and I'll keep posting my progress.
Ol' Papi
FM 1000 - by Ol' Papi - 05-29-2024, 06:16 PM
RE: FM 1000 - by klondike98 - 05-30-2024, 12:39 PM
RE: FM 1000 - by Arran - 05-30-2024, 02:53 PM
RE: FM 1000 - by Paul Philco322 - 05-30-2024, 04:36 PM
RE: FM 1000 - by Ol' Papi - 05-30-2024, 06:25 PM
