Philco 643 color scheme and modification
bandersen Wrote:Yes, I do plan on using an AC supply to create the necessary DC voltages.
The cabinet and escutcheon are in good shape other than a hole someone drilled in the side! I plan on refinishing it very soon. I have all the toner lacquer, grain filler, etc on hand.
I hope it turns out as well as Ron's 650B Icon_smile
The one item I do need is a speaker. It uses an early style PM speaker I believe. I don't know what the impedance should be though.
[Image: http://farm4.static.flickr.com/3109/3158...b7a2_z.jpg]
Philco 643B front and top by bandersen, on Flickr
Bob;
Are you sure that someone added that hole in the side, some high end battery sets had a push button mounted through the side that was used to activate the dial light while pressed.
Re: Philco 643 color scheme and modification - by Arran - 07-19-2011, 07:22 AM
There are currently 7434 online users. [Complete List]
» 4 Member(s) | 7430 Guest(s)
AvatarAvatarAvatarAvatar
