Philco PT-6 IF can testing
I believe SMD (silver migration disease) doesn't occur until the late 1940s when the miniature slug-tuned IF cans started showing up. It's a risk to do too much other than replace the leads. About the only other thing to consider is cleaning the mica trimmers but only when past environment really affected operation, ie crud factor.
Philco PT-6 IF can testing - by bridkarl - 06-19-2024, 02:56 PM
RE: Philco PT-6 IF can testing - by RodB - 06-19-2024, 04:38 PM
RE: Philco PT-6 IF can testing - by bridkarl - 06-19-2024, 05:39 PM
bridkarl - by bridkarl - 06-22-2024, 12:44 PM
