Philco 643 color scheme and modification
Ron Ramirez Wrote:If Bob's 643B cabinet has a hole in the side, it was added by someone after it left the factory - it did not come out with a hole originally.
I used to own a 643B, and it did not have any holes in its sides.
So since it is not supposed to be there for a pushbutton how does the dial light operate on these sets? Is there some sort of spring loaded switch elsewhere to preserve battery life, it can't be on continously?
Re: Philco 643 color scheme and modification - by Arran - 07-19-2011, 06:44 PM
There are currently 8846 online users. [Complete List]
» 5 Member(s) | 8841 Guest(s)
AvatarAvatarAvatarAvatar
