Why didn't Philco make a multiband portable?
One has to wonder how things might have worked out if Philco had just concentrated on radio and television instead of everything? I'd never thought about Philco not building an 'all wave' portable before this. Not like they didn't have tube portables, so a T.O. clone shouldn't have been that far-fetched.
Re: Why didn't Philco make a multiband portable? - by Jayce - 07-21-2011, 12:30 PM
There are currently 9675 online users. [Complete List]
» 1 Member(s) | 9674 Guest(s)
