Philco Model 20 Dial Lamp Question
Hi, All:
I have restored one of these before, and for the life of me I don't remember this.  See the attached photo.  This is the bracket that the dial lamp is on.  I believe, from a couple of screw holes dangerously near the speaker opening, that the bracket was screwed to the inside of the radio face, again, like less than 1/4" below the speaker opening.  I'm guessing I just jerked the screws out when I pulled the chassis.  Is this how this dial lamp was mounted originally?  There is for sure no way I can see to mount that bracket to the chassis and get the dial lamp anywhere near the dial.  But I sure don't see how you would put those screws in after the chassis was in place.
Best
Mike
Philco Model 20 Dial Lamp Question - by mboessen - 07-11-2024, 07:28 PM
RE: Philco Model 20 Dial Lamp Question - by morzh - 07-11-2024, 07:56 PM
RE: Philco Model 20 Dial Lamp Question - by morzh - 07-12-2024, 10:38 AM
