Philco Model 20 Dial Lamp Question
https://mcclellans.com/Philco20BRestoration.htm
Here you will see the position. When you put it there, you will see what the holes align with.
Also here is my photo.
I think it is mount on the tuning cap.
Philco Model 20 Dial Lamp Question - by mboessen - 07-11-2024, 07:28 PM
RE: Philco Model 20 Dial Lamp Question - by morzh - 07-11-2024, 07:56 PM
RE: Philco Model 20 Dial Lamp Question - by morzh - 07-12-2024, 10:38 AM
